Re: HP48G display cleaning Message #2 Posted by Todd Garabedian on 17 Feb 2001, 5:53 p.m., in response to message #1 by Rafa
I use a lens blower brush to remove big particles first. Then, depending on the level of goo on the screen, I use either an alcohol based cleaner such as Glass Plus, or, if the screen is dirtier, something stronger like Fantastik. If I use Fantastik, I usually follow up with a moist towel to remove streaks.
Good Luck.
Tidd
