Battery for 88014B used in 9114B Disk Drive? Message #1 Posted by Philip Reagan on 14 Feb 2001, 10:56 a.m.
Does anyone know of a source for the Sealed Lead-Acid battery that is in, at least, the 9914B Disk Drive. The HP Part Number for the battery module is 88014B and it uses a battery with the number: LCR-226P (6V, 2.4Ah/20hr. The replacement is easy but finding the battery is not. I found one on the shelf at a Batteries Plus store but haven't found it elsewhere. DigiKey said it is discontinued and they couldn't recommend a replacement.
In addition, has anyone successfully reconditioned a Lead-Acid?
Thanks
