Re: HP-71B-HP-IL/RS232 vs Carriage Return Message #3 Posted by Reinhard Hawel on 4 Jan 2001, 7:51 a.m., in response to message #1 by Doug Thomas
The 71B does not generate a <CR>. It uses UNIX convention, where the end-of-line character is a <LF> instead of <CR> <LF>, like in modern PCs.
Ever wondered, why there's a BINary and an ASCII mode in all the ftp programs? That's the reason.
BTW: the development of the 71B ROM was made on a UNIX workstation (a HP 9300 machine), so the developers were used to it. PCs were not very common in the glory days (the 71 was developed 1983-1984). For example the 71B Text Editor Module uses regular expressions for search and replace. The editor is similar to EX (which preceded VI).
There's a lot of conversion utilities on the net and it should be easy to write one on the PC (for use only with Text files). I can see, if I find something on my Winchester (hey, nice old word for a HDD, I just felt I had to use it now).
I know, that for printing you can use the ENDLINE string to specify <CR><LF> (ASCII 13,10), but I doubt, that TRANSFORM will use these settings.
