Re: PID Program Listing Message #5 Posted by Ron Ross on 14 Dec 2000, 9:27 p.m., in response to message #4 by Hugo (Quebec,Canada)
You will find a program to compute PID, PI and Pb parameters for the HP67/97 caclulator in a book called "Practical Process Instrumentationa & Control" Volume II. The article is on page 58 and is titled "Calculator program for new controller-tuning method" and takes 224 steps on an HP67. This means it should run on the following "modern HP's", the HP11 (tight fit), Hp15, Hp32s??, Hp42s, HP41 (almost forgot). with minimal changes. If you list a fax, I may photocopy and fax program listing sometime in next week.
