Re: Is there a way to change Red Display Lens Message #2 Posted by John Robinson on 10 Dec 2000, 6:28 p.m., in response to message #1 by Mike
Hi Mike,
I have done a similar thing with a HP41. on the 41, the plastic is glued in, so I basically swabbed some isopropanol around the area to dissolved/soften the glue, then waited of about fifteen minutes before gently pushing the plastic lens out. I don't know whether classics are glued in like the 41, so this may not help at all. The only thing against this method, was the isopropanol left a milky colored stain on the plastic, but I managed to remove this with some car polish.
