How to Configure X25/ACC in HPUX 9000 with modems Message #1 Posted by Goncalo Valadas on 21 Nov 2000, 12:12 p.m.
I have two motorola 3266 Fast modems attached
to a z7400a mux (one on port 0:0 and the other on port 0:1) they are configured to work in sync mode connected thru a telephone leased line (so they are connected all the time).
I've tried two things:
1. First I tried with lapb_sample.answ that looks as follows:
*@(#)NACC lapb_sample.answ $Rev: /main/12 $"
#include "/opt/acc/cfg/ttgendefine"
ttgen
Configuration
system-name "ACC HDLC/LAP-B (ABM) protocol ttgen input file"
program-zlu 100
terminal-zlu 800
logical-term 800
physical-term 800
buffer-pool 3000000
logical-size 252
queue-Limit 200
transmit-limit 100
unack-limit 5000
port-limit 20000
* E1T1-Port-Limit 100000
node-entry 1
Interface-Definition
z7400a 0 0:8 /opt/acc/z7400a/hdlc.zabs
Port-Definition
Port 0:0 RS232 9600 Int SDLC X1 NRZ
Port 0:1 RS232 9600 Ext SDLC X1 NRZ
Port 0:2 RS232 9600 Int SDLC X1 NRZ
Port 0:3 RS232 9600 Ext SDLC X1 NRZ
Port 0:4 RS232 9600 Int SDLC X1 NRZ
Port 0:5 RS232 9600 Ext SDLC X1 NRZ
Port 0:6 RS232 9600 Int SDLC X1 NRZ
Port 0:7 RS232 9600 Ext SDLC X1 NRZ
Terminal-Definition
Term 10 0:0 HDLC.LAPB HDLC_DTE_400MS 1000 0 0 0 0 "HDLC link 1"
Term 20 0:1 HDLC.LAPB HDLC_DCE_400MS 1000 0 0 0 0 "HDLC link 2"
Node-Definition
Local-Node 123
End$
and zmasterd bring the x25server working. Then I used Zterm utility to verify the configuration and when I try to enable the link:
rc 10 20
cn 10 20 EN
rx
it replies with:
Link not established on enable
so nothing done...
2. Then I try to do the loop test: I've used x25_loop.answ that look as follows:
**ttgen input file /opt/acc/cfg/x25_loop.answ Created Wed Aug 30
18:03:06 PST 2000
**@(#)ACC sample_header $Rev: /main/6 $"
ttgen Configuration
System-name "ACC ttgen input file"
Program-zlu 100
Terminal-zlu 1000
Logical-Term 800
Physical-Term 800
Buffer-Pool 3000000
Logical-Size 252
Logical-Data 10 X25CNT,0,X25CNT_LDSIZE
Queue-Limit 200
Transmit-Limit 100
Unack-Limit 5000
Port-Limit 20000
Node-entry 1
z7400a 0 0:8 /opt/acc/z7400a/x25.zabs
Port-Definition
Terminal-Definition
Term 600 0:0 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 601 0:1 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 602 0:2 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 603 0:3 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 604 0:4 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 605 0:5 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 606 0:6 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 607 0:7 PORTTEST 0000h 0000h 99 0 0 0 0 "For Loopback Test"
Term 608 0:0 MONITOR 0000h 0000h 01 0 0 0 0 "Used for Watch
Feature"
Node-Definition
Local-Node 123
End$
and again zmasterd bring the x25server working. Then I used zx25init to
enable the link:
zx25init -c /etc/x25/x25configCPI_0 -a /etc/x25/ip_to_x121_map
(>>result)
and the same for the other
zx25init -c /etc/x25/x25configCPI_1 -a /etc/x25/ip_to_x121_map
(>>result)
and then the read data led from one modem start flushing and on the other modem the read data led stays on but on /var/opt/acc/log/xxx.tlog file it appears the same message: Link not established on enable.
Here file x25configCPI_0 and x25configCPI_1 :
#@(#)NACC x25configCPI_0 $Rev: /main/2 $"
x.121 408746500000
x.121_packetaddr 408746500000
device zx25m0p0
name natacc00
# Level 2 Parameters
t1 1600
t3 60000
framesize 149
n2 10
l2window 7
# Level 3 Parameters
networktype DTE_84
# Circuit Table Definition
# LCI TYPE HOW MANY
lci 1 pvc 2
# Flow Control, Throughput Class, Fast Select and Reverse Charge
Settings
flowcontrol off
thruputclass off
fast_select_accept disabled
reverse_charge disabled
def_inpacketsize 128
def_outpacketsize 128
def_inwindow 7
def_outwindow 7
def_inthruputclass 11
def_outthruputclass 11
# IP Parameters
ipaddress 130.9.192.0
idletimer 45
holdtimer 30
mtu 2048
#@(#)NACC x25configCPI_1 $Rev: /main/2 $"
x.121 408746500100
x.121_packetaddr 408746500100
device zx25m0p1
name natacc01
t1 1600
t3 60000
framesize 149
n2 10
l2window 7
networktype DCE_84
# LCI TYPE HOW MANY
lci 1 pvc 8
Settings
flowcontrol off
thruputclass off
def_inwindow 7
def_outwindow 7
# IP Parameters
ipaddress 130.9.192.1
idletimer 45
holdtimer 30
mtu 2048
can anybody help me ???
Goncalo Valadas
Edisoft, S.A.
Lisboa-Portugal
