Re: hmmmm... doesn't work for me Message #3 Posted by Mike on 19 Nov 2000, 12:29 a.m., in response to message #2 by Erik Wahlin
I guess I might have to try and build up the cut corner per your article. I tried putting a card in from the other side and I can
never get the card to read correctly, once I have tried to write to the card.
If I don't put the 2nd card in from the left, I get the write error as you would expect.
If I do put the 2nd card in from the left, I don't get the write error. But, when I try to read the card back, I get an error.
I have tried this dozens of times and never get it to read back. I have also tried putting the card in from the left side at various
depths and nothing seems to work. The card I am trying to write to does push the card out of the way ok and does appear to
write (at least no errors) but it just won't read back. I have tried other cards with same results.
