Re: Question on HP41CV Message #6 Posted by John Robinson on 13 Nov 2000, 7:35 p.m., in response to message #3 by Iqbal
Iqbal,
You need to open the calc, lay it face down, locate the small hole behind the "switch" if interest, and give it a squirt through the tube you get with spray pacs. It may not be immediately better, in fact it may be worse initially, but some "exercise" will make it as good if not better than before, hopefully better !!. Cheers - John
