Re: HP-75 Card Reader Commands Message #2 Posted by Gianmaria (Italy) on 30 Oct 2000, 12:34 p.m., in response to message #1 by Mike Davis
The COPY command allow you to copy the programs from the magnetic cards to the HP-75. The correct use for that command is:
COPY CARD TO 'the name of the program you want to copy'
the response of the 75 is:
Copy from card: Align & [RTN]
Now press the RTN key and the 75 says:
Pull card...
Now you have to pull the card not too fast and not too slow.
If you want to copy a program from the 75 to the card this is the command:
COPY 'name of the file' TO CARD
then press RTN and pull the card...
Hope all that help you.
Best Regards.
Gian
http://welcome.to/gian
