Re: Problem with display on HP41CX Message #4 Posted by John Robinson on 30 Oct 2000, 7:45 a.m., in response to message #3 by Iqbal
Iqbal, If you are seeing all segments on, but some are dimmer than others, then your problem is the contact strips between the display glass and the display circuit board. I take it we are talking about a halfnut ?. You need to unsolder the display, remove the black metal clips, clean the contacts on the circuit board, display glass, and contact strips. Reassemble, and that should fix it.
