HP48gx to computer connection problem Message #1 Posted by r. d. bärtschiger. on 22 Oct 2000, 7:58 p.m.
I have recently experienced an intermittent problem connecting my HP-48gx to my computer. When I run Kermit on the computer I receive an error message '?Warning: unknown hardware for port. Using the Bios as BIOS1'. At this point it becomes impossible to execute a transfer between the two devices. Usually simply re-booting would solve this problem, or on occasion it might be necessary to shut down the computer then turn it on again and reboot. Lately, however, it has become necessary to remove 'com1' from 'system properties, device manager' and then re-install 'com1' by re-booting the computer. After this procedure all is again well. I am using MS-DOS Kermit: 3.15 15 Sept 1997 patch level 0, downloaded from the kermit site. After receiving the above error message, although I can not transfer any files, I am still within Kermit. At this point if I execute 'test com1', another error message is returned, 'Not an 8250 UART at this COM port'. After re-installing the com port, entering Kermit and again executing 'test com1', the response is 'UART tests ok'. So far I have been unable to isolate whatever it is that triggers this error condition.
Does anyone have any idea about what the problem might be? Thank you for your time.
rdb.
