Re: Are CPU boards for 41C / CV / CX interchangable (more) Message #3 Posted by John Robinson (Australia) on 10 Oct 2000, 11:24 p.m., in response to message #1 by David F.
But ... something to keep in mind if your transplanting across different age machines : The CPU boards can vary in thickness depending on their age, the older ones being thicker than the newer ones. Also, the case backs vary as well, some press against the CPU board, and some don't. You may need to use the spacer washers (those white nylon things) depending on the CPU board thickness and type of case back. - John
