Re: HP 15C Message #2 Posted by William L. Drylie on 9 Oct 2000, 10:07 p.m., in response to message #1 by Lisa
Lisa.
The section in the manual for Calculating With Matrices is about 41 pages. If you e-mail your address to me, I would send you a reprint.
For now, I will get you started with an example from the manual.
The 15c can work with up to 5 matrices which are named A through E using the 15's corresponding A through E keys. You can specify the size of each matrix, store and recall values of matrix elements and perform matrix operations with complex and real elements. Consider the example.
3.8x1 + 7.2x2 = 16.5
1.3x1 - 0.9x2 = -22.1 determine the values of x1 and x2.
Keystrokes:
g CF 8 deactivates complex mode.
2 Enter f DIM A dimensions matrix A to be 2X2
f Matrix 1 prepares for automatic entry of matrix elements in user mode.
f USER turns on user annunciator
3.8 STO A Denotes Matrix A row 1 column 1
7.2 STO A
1.3 STO A
.9 CHS STO A
2 ENTER 1 f DIM B Dimensions matrix B to be 2X1
16.5 STO B
22.1 CHS STO B
f RESULT C designates matrix C storing the result.
RCL MATRIX B
RCL MATRIX A
/ press divide key
RCL C displays 1, 1 (row 1, column 1)
-11.2887 (value of (X1))
RCL C 8.2496 (value of (X2))
f USER deactivates user mode
f MATRIX 0 Clears all matrices.
The solution to the system is X1 = -11.2887 ans X2 = 8.2496.
Up to 64 matrix elements can be stored in memory. Use all 64 in one matrix or distribute them among up to 5 matrices. Matrix inversion can be performed on an 8X8 with real elements or a 4X4 with complex elements.
If you have need of further help, I suggest you e-mail me directly at wldrylie@702com.net. I will help more. Or e-mail mailing address, I will send you 15C reprint of matrix section of manual. Good luck. I still have fun using my 15C at work. I can also provide many an engineering example from my daily work and programs. Let me know.
Bill.
