Re: Oops! Wrong wires Message #3 Posted by Mike Davis on 8 Oct 2000, 7:38 p.m., in response to message #2 by Katie Wasserman
Thanks but the wires I am talking about are not on the interface board.
They are the two wires that come from the charger connector.
There is a white-red wire connected to the third terminal on the charger connector (opposite from the Red wire).
There is a white-black that is connected to the center pin on that same connector.
These two wires go to the board that the LED display is mounted on. There are two small pin connectors in the corner, right next to a transistor. Both connections are friction fit.
Which goes to which?
Mike
