Re: How to remove the Classic back label Message #2 Posted by Gianmaria (Italy) on 5 Oct 2000, 3:10 a.m., in response to message #1 by Hugo
You could start to take a look at following John Robinson's message: Classic series back label removal, John Robinson - 14 Aug 2000, 8:01 p.m. However you can use an hair-dryer until the upper corner of back label is quite hot, then you can carefully lift it. You have to repeat that step also with other corner. Let me know how do do you think. Greetings! Gian
