Re: HP65 card reader problem Message #2 Posted by Matthew Riehl (U.S.A.) on 15 Sept 2000, 5:39 p.m., in response to message #1 by john kegan
You can replace the roller with standard hardware store O-Rings. I believe that they are .125" I.D. and .250" O.D., but check the "How To" article in the Article Forum on this website for exact dimensions. Just remove the old rubber from the internal metal shaft, clean everthing thoroughly, and put the O-Rings where the original rubber was.
You don't need any special tools, just small screw drivers and maybe a set of needle nose pliers. I did invest in a small set of screw drivers from Radio Shack, just to have some good quality small screw drivers more than anything else.
Matthew Riehl
