Sure can! Message #2 Posted by Joe Panico on 6 Sept 2000, 10:54 a.m., in response to message #1 by Tal
Tal,
Still exploring the 48 I see. Changing the menu is easy if you use some SystemRPL commands. I'll list a simple program and the way to change.
{ "START" "GO" "NOW" "" "" "EXIT" } the menu
-> menu make a local var
menu TMENU show menu
menu 1 {"STOP"} REPL change menu
TMENU #3A1FCh SYSEVAL display current menu
That's it! You still follow all the commands that display the menu. Generally, the 48 displays a menu when the system is ready for keyboard input (HALT or WAIT). Using the SYSEVAL (for DispMenu.1) accomplishes the same things without needing the HALT or WAIT.
Tip! Use this feature to blank the menu during segments of programs, it looks better.
Joe
