Re: help with 29c please Message #8 Posted by Viktor Toth on 6 Sept 2000, 8:37 p.m., in response to message #7 by Glynn
A couple of comments, in the hope that it'll reduce the number of freshly killed HP-29Cs out there...
A new alkaline "AA" battery can deliver a voltage as high as 1.6 Volts, which means 3.2V for a pair of them. I would think that this is within tolerance, but I've heard horror stories that this was enough to kill continuous memory models.
A fully charged NiCd battery can deliver as much as 1.45V briefly after the end of the charging cycle. During charging, the voltage on the terminals may even be higher than that, so the 25C/29C were obviously capable of accepting an input voltage of 2.9V or a bit more.
Using alkaline batteries and the charger may indeed not cause a spectacular explosion but the results won't be nice no matter what.
"AA" size NiCd cells are easy to find, they're cheap, and can be used with the same ease as alkaline cells, once you cut the plastic case of the battery pack open.
Because of corrosion on Woodstock battery contacts, I am hesitant these days when it comes to using the charger on 'C' models even with a rebuilt battery pack. Remember, in these models the RAM is always under power! If the battery doesn't make good contact, the calculator may momentarily receive a voltage far in excess of 2.9V (10V or more!!!), which is enough to kill the RAM and perhaps other chips. It is best to charge the batteries in a non-CMOS model (e.g., an HP-25) and avoid turning the calculator on while the charger is in.
Viktor
