Re: HP 9114A IL Drive Message #7 Posted by Thibaut on 24 Aug 2000, 9:45 p.m., in response to message #6 by Steve
WOW ! What a long answer !
>I'm assuming that there's no warning lights...
>Then (in order of decending probabilities):
>1) you have a fault in the HP-IL interface of the drive
could be
>2) the battery level is way too low for the drive to work
powered by a transformer, seems to power up correclty
>3) the drive is not turned on
welll it was
>4) one of your HP-IL cables just broke
other IL devices work perfectly
>5) the HP-IL connectors on the drive are somehow faulty
could be
>6) you just developed a fault in your HP-IL interface
could be
>7) you are misreading 0.0000 as TRANSMIT ERR :-)
well... huh....
>Assuming that you know how to turn on the unit, then 1 is >the most likely, 2 is a possibility, 3 means it's time to >>slap yourself around a bit, 4 is just silly (assuming >you've tested your HP-IL interface on the cassette drive), >5 is a rather remote possibility (I'd put it behid a cable >break), 6 is well, i've never actually seen a broken HP-IL >interface, and 7 is... umm... a joke :-)
>You've got to understand that it's early in the morning >here, and I say some silly things when I've just gotten up.
No problemo, I have sense of humor !
>Back to sensibility...
>Are you familiar with the start up self test these drives >do?
No
>Do you have the unit with 2 lights, or 4 (or was that 5)?
3 lights actually, one power on, one "fault", one that should turn on when the drive is running
>Have you replaced the battery? (Or confirmed it it OK) >Note that this unit WILL NOT run from the charger alone.
it has been adapted and seem to be powered perfeclty. The seller pretends it worked with a 71B before
>If you turn it on with a disk in it, the drive will do a >self test. If this results in no flashing lights, then the >drive thinks it's OK.
It is then OK
>The drive with 2 lights has one (the left one I think) as >a battery low indicator. The newer version with more >lights has them set up as a fuel guage, i.e. more lights >means more charge available. For testing, make sure that >they're ALL on, otherwise the drive may decide to stop >doing certain things (i.e. writing to the disk)
>The internal battery is a SLA battery. I't easy to >replace, but if there's problems with your drive, then >maybe you don't want to go for that expense. If you're a >bit handy with things, then you probably could replace it
>(temporarily) with 4 nicads of whatever size will fit. >Don't expect the charger in the battery pack to work >correctly with them though.
It is a power adapter that seem to come from educalc
>Openning up the unit requires a #8 (from memory) TORX
>(again, from memory) screwdriver. They're the ones that >look like an alen key except they have scalloped faces
>(concave). The screws are so far down little thin holes >that you really need a screwdriver. I took my drive under >my arm to an electronics store and tried all the TORX >drivers until I found one that was the right size and long >and thin enough.
>Once you take the bottom off (remove the battery first) >you'll see the drive and a single large PCB. You'll also >see the HPIL connectors and where they conect into the >board. Maybe the connectors have become lose or something >>(I can't see that's likely unless someone's been there before you).
>Ah, I just noticed the title says 9114_A_. That's the one >with 2 lights on the front -- yes?
correct
>Even if the dive does not work, then there are parts that >are valuable in getting another drive to work. At the very >least the drive itself (the drives are different between >the A and B versions) and the battery pack (some seem to >be missing this) are items that you can swap to other >units.
>The drives are so big and chunkey that you can actually >repair them! I removed and reattached the head of one (in >a 9114A) because it had become bent out of shape (well the >suspension for the head had). If you think it's fiddly to >put a card reader back together, then a disk drive is even >worse. There's springs in there that work against you.
I don't pretend to go into that deep !
>Oh, check that your drive has heads! The common fault of >these drives is that the lubricant hardens and the eject >mechanism slows down. After a point, the eject must be >completed manually (i.e. you have to pull the disk out) If >this is the case, then it is quite possible that the heads >are not out of the way, and the disk shutter will tear >them off (or in my case just bend them way out of shape). >If pushing the eject button (without a disk in the drive) >just makes something in the drive go up and down, and it >doesn't latch, then your drive has it BAD and may have
>head damage.
It seems OK
>This too is easy to fix if you catch it early. Take out >the drive (the earth lead can be a pain to remove, and you >will probably have to move the the main board (just a >little) to get the screws back in (same as the ones that >hold the cover on). Then take off the cover off the 3 1/2 >inch drive. 1 screw does this on both types I think?? Or >maybe one clips off. Then you'll be able to see the levers >and things that make the eject mechanism work. They are >all down one side of the drive.
>Now get a cotton swab or something and using alcohol, or >degreaser or something that will act as a solvent for the >grease, wipe away the old hard grease. remember that it's >behind things too, so work the eject mechanism, and get >the grease out from behind everything you can. At some >point the eject mechanism will start to work again. If it >hasn't been latching, the first indication is when a small >lever jumps up and locks the drive in the eject position. >This is a good thing, but it does not mean you've got all >the gunk out. The eject should be snappy. When it is, put >the drive down and come back tomorrow.
>The drive will no longer work! The solvent had softened >some of the grease, and heat had done it's part too. So >start again, and get the drive working again. (Then again, >maybe you're lucky (or thorough) and did a good job the >first time)
>Keep repeating this until the drive works the next day, or >you get sick of it.
>Now use a light machine oil to LIGHTLY lubricate the parts >that obviously move against one another and work the drive >to make sure the oil gets to where it's needed.
>Then put it all back together.
>OK, I'll admit it. After I get the thing ejecting again I >put it back together to make sure everything still works, >but sure as eggs, it's gummed up again the next day, so I >go back through the routine again until I've done it >properly.
>I've used this technique on about 10 drives of this >vintage, and assuming there was no head damage, have had >100% success. I've only had one drive with head damage >that was recoverable. In hindsight, the only reason why I >attempted the fix this one, rather than earlier ones is >that when I first did this there were quite a lot of >drives (the 3 1/2 drives, not the 9114 units) around, and >binning one was not such a bad thing.
Huh... it is a 3/12 drive ?! actually !
>This should more than answer your question, and possibly >arm you to find and fix these units :-)
Well, after all this information, (I suggest you put one or two graphs, you've written a good collaboration for this site, David could certainly post it on the repair forum !), I don't have much to loose and will try all you said !
Many thanks anyway ! I'll keep you informed !
