HP Forum Archive 03
My manual is packed away. Can anyone tell me the syntax of this command. I type in numbers but it either says nothing or stops with a data error.
I want to dump the contents of memory and I think this is the easiest method.
do you have a printer pluged in trace mode? if not, it will not work ! Please ask if you need help! thib.
