Re: interfacing a 41 with a 48 thru IR port Message #5 Posted by Viktor Toth on 17 Aug 2000, 11:48 p.m., in response to message #1 by thib
Using IR is actually the preferred method of transferring programs from a 41C to your HP-48SX if you happen to be using the HP-41CV emulator card.
Speaking of which, can anybody confirm whether this emulator card is indeed incompatible with the HP-48GX? I believe I read somewhere that it is, but I'm not sure; it works fine in my HP-48SX, but not in my HP-48GX.
Viktor
