Some Basics about IR transmission Message #9 Posted by Steve on 30 July 2000, 5:04 a.m., in response to message #8 by Katie Wasserman
Ahhh, it's simple enough!
Basics
The carrier frequency is 32.768Khz. (for the HP-18C)
The carrier has an even mark and space of approximately 15.26uS
The carrier is modulated by a square wave with a fixed mark, but variable space. Thus the information is carried by the gaps between pulses, not the pulses themselves!
Data Encoding
The data is encoded bit by bit. Bit times are fixed (28 pulses of the carrier, or approx 854.5uS). This bit time is broken into two halves.
* A 1 bit is defined as a burst in the first half of the bit time, and no pulse in the second half
* A 0 bit is defined as a burst in the second half, but not in the first half.
* A start bit is defined as a burst at the begining of three successive half bit times (an otherwise illegal combination)
Note that this makes a start bit 50% longer than a normal bit.
An Example
If I were drawing things, it would look like this:
(this is a start bit followed by a 1 and a 0.) Note that you don't start counting until you see the first rising edge. To make things easier, I only show 4 pulses per 1/4 bit time, rather than the 6 to 8 that you may see in practice.
Also note that while HP talks of 1/2 bit times, you can usefully think in terms of 1/4 bit times with the even 1/4's ALWAYS in a space, and the mark only ever occuring in one of the odd 1/4's.
___||||____||||____||||____||||________________________||||____
To break that up:
___ is some amount of space between characters
||||____||||____||||____ is three half bit times with pulses in their first half. (and is thus a start bit)
||||____________ is two half bit times with pulses in the first half bit time (a 1)
________||||____ is two half bit times with pulses in the second half bit time (a 0)
Data is sent in frames. Each frame consists of a start bit, 4 ECC bits, and 8 data bits.
If you look at the output of one of these IR devices on a storage scope, or via some other method, you'll notice immediatly that the frames stand out like islands of data in the sea of noise. As you look closer you'll see the groups of pulses and the spacing between them. You'll notice the three different size gaps. These are 1 unit, 3 units, and 5 units. Coding these gaps is actually one way of coding the data.
A Table to Cheat By :-)
Here is a table that some of my software uses to decode these gaps. Note that it was devises BEFORE I knew anything about how te data was decoded.
const
FrameChars : Array[0..255] of string[14] = (
'11222222222222', // 0
'11221232222221', // 1
'11213132222213', // 2
'11212322222212', // 3
'11212322222132', // 4
'11213132222131', // 5
'11221232222123', // 6
'11222222222122', // 7
'11132132221322', // 8
'11131322221321', // 9
'11123222221313', // 10
'11122232221312', // 11
'11122232221232', // 12
'11123222221231', // 13
'11131322221223', // 14
'11132132221222', // 15
'11131322213222', // 16
'11132132213221', // 17
'11122232213213', // 18
'11123222213212', // 19
'11123222213132', // 20
'11122232213131', // 21
'11132132213123', // 22
'11131322213122', // 23
'11221232212322', // 24
'11222222212321', // 25
'11212322212313', // 26
'11213132212312', // 27
'11213132212232', // 28
'11212322212231', // 29
'11222222212223', // 30
'11221232212222', // 31
'11123222132222', // 32
'11122232132221', // 33
'11132132132213', // 34
'11131322132212', // 35
'11131322132132', // 36
'11132132132131', // 37
'11122232132123', // 38
'11123222132122', // 39
'11213132131322', // 40
'11212322131321', // 41
'11222222131313', // 42
'11221232131312', // 43
'11221232131232', // 44
'11222222131231', // 45
'11212322131223', // 46
'11213132131222', // 47
'11212322123222', // 48
'11213132123221', // 49
'11221232123213', // 50
'11222222123212', // 51
'11222222123132', // 52
'11221232123131', // 53
'11213132123123', // 54
'11212322123122', // 55
'11122232122322', // 56
'11123222122321', // 57
'11131322122313', // 58
'11132132122312', // 59
'11132132122232', // 60
'11131322122231', // 61
'11123222122223', // 62
'11122232122222', // 63
'11122321322222', // 64
'11123131322221', // 65
'11131231322213', // 66
'11132221322212', // 67
'11132221322132', // 68
'11131231322131', // 69
'11123131322123', // 70
'11122321322122', // 71
'11212231321322', // 72
'11213221321321', // 73
'11221321321313', // 74
'11222131321312', // 75
'11222131321232', // 76
'11221321321231', // 77
'11213221321223', // 78
'11212231321222', // 79
'11213221313222', // 80
'11212231313221', // 81
'11222131313213', // 82
'11221321313212', // 83
'11221321313132', // 84
'11222131313131', // 85
'11212231313123', // 86
'11213221313122', // 87
'11123131312322', // 88
'11122321312321', // 89
'11132221312313', // 90
'11131231312312', // 91
'11131231312232', // 92
'11132221312231', // 93
'11122321312223', // 94
'11123131312222', // 95
'11221321232222', // 96
'11222131232221', // 97
'11212231232213', // 98
'11213221232212', // 99
'11213221232132', // 100
'11212231232131', // 101
'11222131232123', // 102
'11221321232122', // 103
'11131231231322', // 104
'11132221231321', // 105
'11122321231313', // 106
'11123131231312', // 107
'11123131231232', // 108
'11122321231231', // 109
'11132221231223', // 110
'11131231231222', // 111
'11132221223222', // 112
'11131231223221', // 113
'11123131223213', // 114
'11122321223212', // 115
'11122321223132', // 116
'11123131223131', // 117
'11131231223123', // 118
'11132221223122', // 119
'11222131222322', // 120
'11221321222321', // 121
'11213221222313', // 122
'11212231222312', // 123
'11212231222232', // 124
'11213221222231', // 125
'11221321222223', // 126
'11222131222222', // 127
'11212223222222', // 128
'11213213222221',
'11221313222213',
'11222123222212',
'11222123222132',
'11221313222131',
'11213213222123',
'11212223222122',
'11122313221322',
'11123123221321',
'11131223221313',
'11132213221312',
'11132213221232',
'11131223221231',
'11123123221223',
'11122313221222',
'11123123213222',
'11122313213221',
'11132213213213',
'11131223213212',
'11131223213132',
'11132213213131',
'11122313213123',
'11123123213122',
'11213213212322',
'11212223212321',
'11222123212313',
'11221313212312',
'11221313212232',
'11222123212231',
'11212223212223',
'11213213212222',
'11131223132222',
'11132213132221',
'11122313132213',
'11123123132212',
'11123123132132',
'11122313132131',
'11132213132123',
'11131223132122',
'11221313131322',
'11222123131321',
'11212223131313',
'11213213131312',
'11213213131232',
'11212223131231',
'11222123131223',
'11221313131222',
'11222123123222',
'11221313123221',
'11213213123213',
'11212223123212',
'11212223123132',
'11213213123131',
'11221313123123',
'11222123123122',
'11132213122322',
'11131223122321',
'11123123122313',
'11122313122312',
'11122313122232',
'11123123122231',
'11131223122223',
'11132213122222', // 191
'11132122322222', // 192
'11131312322221',
'11123212322213',
'11122222322212',
'11122222322132',
'11123212322131',
'11131312322123',
'11132122322122',
'11222212321322',
'11221222321321',
'11213122321313',
'11212312321312',
'11212312321232',
'11213122321231',
'11221222321223',
'11222212321222',
'11221222313222',
'11222212313221',
'11212312313213', // 210
'11213122313212',
'11213122313132',
'11212312313131',
'11222212313123',
'11221222313122',
'11131312312322',
'11132122312321',
'11122222312313',
'11123212312312',
'11123212312232', // 220
'11122222312231',
'11132122312223',
'11131312312222',
'11213122232222',
'11212312232221',
'11222212232213',
'11221222232212',
'11221222232132',
'11222212232131',
'11212312232123', // 230
'11213122232122',
'11123212231322',
'11122222231321',
'11132122231313',
'11131312231312',
'11131312231232',
'11132122231231',
'11122222231223',
'11123212231222',
'11122222223222', // 240
'11123212223221',
'11131312223213',
'11132122223212',
'11132122223132',
'11131312223131',
'11123212223123',
'11122222223122',
'11212312222322',
'11213122222321',
'11221222222313', // 250
'11222212222312',
'11222212222232',
'11221222222231',
'11213122222223',
'11212312222222' ) ; // 255
This table encodes the GAPS between modulation pulses for each character. 1 indicates a short gap, 2 the middle size gap, and 3 the long gap. Knowing that the pulses fit around each gap, that the gaps are in the proportion 1:3:5, and that you should send 7 carrier pulses at 32767Hz, this is probably enough info.
How To Cheat
So, character A is 65 and is '11123131322221'
You would send:
|_|_|_|___|_____|_|_____|_|_____|___|___|___|___|_|
Where each | is 7 carrier pulses, and each _ is a gap of equivalent size.
If you're further interested...
SSSSSS111111110000111100001111000000000000000000001111
And yes the 1's do extend out beyond the end! This is becasue the last set of pulses occur in the first quarter of the last bit time (first half of the first half of the last bit time!!!). So even though we're encoding information in the gaps, the last gap does not need to be terminated.
SSSSSS = start bit
1111 = 1 bit
0000 = 0 bit
So it was S110101000001
1101 is the ECC
01000001 is the code for A in ASCII MSB first
Calculating the ECC
How do we get the ECC? well it's like this...
The 4 bits (call them H1, H2, H3, and H4) are calculated individually
Firstly for each bit you apply a mask (AND) to the data
the masks are:
H1 01111000
H2 11100110
H3 11010101
H4 10001011
So for the code 01000001 the resulting data for these is
H1 01000000
H2 01000000
H3 01000001
H4 00000001
Then you calculate the EVEN parity bit required for these (i.e. the bit required so that there are an EVEN number of bits. Since H1, H2, and H4 have an odd number of bits, the parity bit for these would be 1, bit for H3 it is 0.
Then you string them together (the parity bits) this gives you:
1101 which is what we found above!
These parity bits can be used to detect and correct up to two missed bits (though how you do that is well beyond what I'm prepared to go into!)
But, my software DOES decode these without resorting to calculating the ECC bits (although I may add that some time)
But you're trying to SEND this data right? So the lookup table I've given you should be all you need, unless you want to do all the hard work yourself :-)
P.S.
An easy way to play with this is to capture it with your sound card... (Oh damn, I've let out my secret). It has the advantage of handling all the timing for you, so software speed is no longer an issue. This is especially important when using an operating system that multi-tasks.
An observation about formating
You can really stuff up the formatting (especially with the pre: tag if you include a ']' in your text. Our esteemed host has allowed things like '\]' for ']' (and thus '\[' for '[') to escape the special processing as I've just discovered.
Thanks :-D
I may even write an editor to make this process somewhat faster. Formatting really takes a while to do... Anyone interested?
