Double or half speed on your HP-42S Message #2 Posted by menno on 19 July 2000, 5:53 a.m., in response to message #1 by Gil Petri
HP Forum Archive 2 [ Read Responses | Return to the Index ] [ Previous | Next in Thread | Next ]
Speed up a HP42S and some more Posted by Menno on 3 May 2000, 2:53 a.m. This is for the 42-users: To speed up (or slow down) a 42 temporarely do the next: Press [on] and [log] and then [<-] Go to adress 40300:7 change the 7 in a F (dubble speed) Change the 7 in a 0 for half speed. To leave this mode goto 00000:00 type [.] You are now in operating mode. Switching the 42 off resets it to normal speed or whatever for change you've made will be reset to standard setting (very fool-proof). If you're planning not to use your 42 for a while you can put it in a deep-sleep-mode press [on] and [+] and [XEQ]. This will save batteries. If you want to be annoying type the next program on somebody else his 42: LBL"KILL" SF11 OFF GTO"KILL" END. To get out of this loop press quickly [R/S] or [ON] and [Vx]. Flag 11 can also be used for "autoexec"-ing a normal program like "smily" (can be found in the 42 manual) Menno
Responses HP42S tricks, Andrés C. Rodríguez - 3 May 2000, 12:01 p.m. Re: HP42S tricks, Menno - 4 May 2000, 2:40 a.m. Re: Speed up a HP42S and some more, Thibaut - 4 May 2000, 10:26 p.m.
