Re: Cleaning Up NiCad Mess Message #6 Posted by Carlos Tolossa on 11 July 2000, 10:48 p.m., in response to message #1 by Fred Towers
Guys, this is what I've done and it works: The dry brush trick is fine but in addition, I've used the vacuum cleaner to suck all the crystal from the inside of the case, (if interior of case is accessable, better yet..), then I used a sodium free battery acid neutralizer made by JV manuf. 800.334.9092. With a Q-tip, clean the areas that were exposed to battery acid, let it set for 5 minutes, this liquid will turn yellow when neutralizing and light purple when contaminating areas are neutralized. Dry it thoroughly. Then, before you close the battery compartment, insert a tiny bag of silica-sorbent in it (sold by Multisorb Technologies 800.445.9890). Case solved. I've used this trick on a lot of the Spice 30E/C series. and lots of 41C series. The liquid neutralizes and arrest corrosion on plastic or metal due to batt leaks . Legal disclaimer note..... I do not have vested interest on any of these companies nor the products they represent, read and follow product label instructions, use at your own risk, result may vary from case to case. Good luck...
