HP Forum Archive 03
HP 11C English Display
Message #1 Posted by Andy Reese on 3 July 2000, 12:23 p.m.
My HP11C displays in english mode and I don;t know how to change it back. The comma is where the decimal should be - driving me nuts. Can someone with a manual tell me how to change it back? Thanks.
Re: HP 11C English Display
Message #2 Posted by r. d. bärtschiger. on 3 July 2000, 1:03 p.m.,
in response to message #1 by Andy Reese
I don't have an 11c, however the following is the sequence for a 12c; Turn OFF, hold down the . key, that is the decimal point key, and then turn ON. Hope this works for you.
take care.
rdb.
Message #3 Posted by Carloa Tolossa on 3 July 2000, 2:33 p.m.,
Mr. rdb is correct *A-while calc is off, press "ON" and "." simultaneously. *B-Release the "ON" and then release "." Calc should go back to decimal form. To change back to comma form repeat step A&B (same sequence)
Message #4 Posted by Thibaut on 3 July 2000, 4:15 p.m.,
Yes, I confirm that the ON/. sequence toggles between XXX.XXX.XXX,XXXXXX and XXX,XXX,XXX.XXXXXX mode.
