Re: Where could I find the addresses of the SYSEVAL command for HP48? Message #2 Posted by William L. Drylie on 2 July 2000, 5:32 p.m., in response to message #1 by Tal
Tal,
Go to http://www.engr.uvic.ca/~aschoorl/ see programming section and select supported entries to view a list of supported object addresses which is quite lengthy. Be careful, at the bottom is a list that works with G series only, since you did not specify which 48 you were working with.
William L. Drylie
