Re: How to UN-Private a program Message #7 Posted by Paul on 21 June 2000, 6:54 p.m., in response to message #6 by Steve
Refreshing tid bits :) 1. I am using a 41CX 2. The programs were loaded via the 82014A Card Reader ============================================================
Now, I'll list your steps and my results in brackets[RESULT]
GTO.. [0.00]
PRGM (to put calc into Program mode) [00 REG 210]
LBL "XXX" (Enter this) [01 LBL'XXX]
GTO.. [00 REG 209]
CAT 1 (Stop when LBL XXX shows in display) [LBL'XXX]
SST [END 10]
SST (Displays .END. REG XX) [.END. REG 209]
ALPHA (Place calculator in Alpha mode)
CLX (display is 4094 END) [4094 END]
BST (display is 4093 LBL"XXX") [4093 LBL' XXX]
BST (display is 4092 END) [4092 END]
CLX (display is 4091 xxxxxx -- last line of private program) [4091 PASN]
SST (display is 4092 LBL"XXX") [4092 LBL'XXX]
CLX (removes label) [4091 PASN]
ALPHA (out of alpha mode) [4091 PASN]
GTO .. [4092 GTO _ _]
This is **BEAUTIFUL** Steve, I had more success as I was placing my output in brackets, this is definately one for the books!
Thanks a lot :)
BTW, I havent seen my code in close to 10 years I would say, was so neat to see PASN in the display!!
