Re: 3 1/2 Inch Floppys For HP9121D Message #5 Posted by Andrés C. Rodríguez on 17 June 2000, 9:20 a.m., in response to message #3 by Fred Ellers
One of the first adopters of 3 1/2 floppies was the first Macintosh computers, recording 400 KBy on each floppy. However, they used a constant linear velocity (or should I call it "variable angular velocity"?), so the formatting is clever but very incompatible with every other use.
If the floppies were pre-formatted at the factory, then you should only look for HP sites.
If there is any way to format the floppies (other than the factory), then many Macintosh, Amiga, Data General One (laptop), Toshiba T1000 (laptop), and MSX machines used "low" density floppies in the 1980s; and you may found some floppies on these environments...
Oh, there were strange things those days, specially in 5 1/4 floppies: double heads on the Apple Lisa, hard sector formatting, with a hole for each sector and a 3 hole index mark ...
