Re: HP-41 Barcode on your PC Message #3 Posted by Leo Duran on 8 June 2000, 7:45 p.m., in response to message #2 by Andrés C. Rodríguez
The raster data is preceded by ESC*b##W, which is a very primitive esc-sequence that I think goes back to the inception of PCL. So, it should work on any PCL compatible printer.
By the way, the utility does not send data to the printer, it simply generates a printable file. Example:
hp41uc /r=prog.raw /w "Program Title" /h
will generate an output file called "prog.wnd". To print the output file, you just copy it to the print device:
copy prog.wnd lpt1
