Re: How do I check a HP82143A Printer without a 41 Message #2 Posted by Erwin on 25 Apr 2000, 6:49 a.m., in response to message #1 by menno
I checked the manual of the printer, and there is no self-test. Just connect printer to calculator -- make sure that both divices are OFF--. Set mode switch of the printer on "TRACE" or "NORM", and turn on calculator and printer. Press a key on the calculator. It should be printed by the printer.
Connect printer to highest port of the calculator.
I/O ports
[ 1 ] [ 2 ] [ 3 ] [ 4 ]
