Re: HP 41CV PROBLEM Message #2 Posted by Wayne Brown on 13 Apr 2000, 9:36 p.m., in response to message #1 by andy terzis
I know you asked for email, but I'm answering here also in case someone else needs this information.
From your description, it sounds as though you've gotten your HP-41CV into "beep mode." This happens when the 41 is interrupted (by pressing ON-BACKSPACE or ON-ENTER) while a tone is sounding. It doesn't always happen, but sometimes the calculator is left in a condition in which a high-pitched tone sounds every time a key is pressed or a program runs. The easiest way to clear it is to issue a BEEP (SHIFT 4) from the keyboard.
