Re: Early 32E Message #1 Posted by Jan H. Bos on 13 Apr 2000, 9:44 a.m.
It is not so bad, if the flexible cable between the battery pack and the circuits is broken. It can be replaced by 3 strips from thin multi core colored flat computer cable. You can make new connections on the tiny board in the calc. Just be sure you use a small soldering-iron of max. 20 watts. I have done this succesfully. Good luck.
