HP-IL Files: Where, What, Why, How, etc. Message #1 Posted by Dan M on 4 Apr 2000, 5:03 p.m.
I finally figured out that I will never get this write-up "finished," so I've put it out online as it is.
Check out the following web page for your reading and HP-IL'ing pleasure:
http://www.hevanet.com/danm/hpilr2_1h.htm
It is all about how to use your _modern_ pc to locate, access, and use HP-IL files WITHOUT the special HP 82973 HP-IL/PC interface card.
You will need a 9114 floppy drive, internet access, and HP-IL capability (I focused on the HP-41, with some emphasis on the HP-71B. The techniques should work for everything else, too)
If you have any questions about it, please send me an email.
Dan
