Re: HP 28S Right Side is Dead Message #2 Posted by Matt on 31 Mar 2000, 11:56 a.m., in response to message #1 by JohnM
Less than a year after I bought my 28C (new) several of the keys on the left side quit working. When I called the HP repair center and asked about returning it under warranty, the technician told me to try blowing around the keys with compressed air first, as that usually fixed it. He said that's exactly what they do, and if it didn't solve the problem they just threw the calculator away and replaced it with a new one as HP considered the 28 non-repairable. Maybe the S version was different but I doubt it. And in fact, blowing mine out "fixed" it, and I've been using it as my everyday workhorse with zero problems since.
Which doesn't necessarily help you since you've opened up the case, but it may explain why you're having so much trouble getting it back together.
