Counted Strings. Message #3 Posted by r. d. bärtschiger. on 24 Mar 2000, 2:38 p.m., in response to message #1 by Jason
Hi Jason;
The result you are getting is normal. It is refered to as a counted string. Normally you would not see the C$ unless you tried to edit the string. This occurs because the string contains double quotes. As an example;
If the display shows
""How Are You?""
that is with two double quotes at the beginning of the string and two double quotes at the end of the string, and you press the down arrow key to edit this string, you will see;
C$ 14 "How Are You?"
C$ means that it is a counted string, 14 is the length of the string and "How Are You?" is the string, with the double quotes. In your case I'll bet you are using double quotes to designate seconds, i.e. 51°13'34" as an example. Because of the double quotes this is converted into a counted string if you attempt to edit it. If you print or display this counted string it will print or display correctly, without the C$. You can also create a string which contains double quotes using this method. Press alpha alpha C$ nn and then the string, where nn is the length of the resultant string, not counting the automatic double quotes placed at the beginning and end of the string by the os. In fact any string can be created this way, although not as easily as simply entering the string. As an example;
C$ 24 This Is A Double Quote "
will result in this string
"This Is A Double Quote ""
on the display.
Hope this has answewred your question and has helped you.
Take care.
rdb.
