HP49g programdownload problem Message #5 Posted by erwin on 21 Mar 2000, 6:05 p.m., in response to message #1 by erwin
I may have found something,But i don't know what i can do with it. There is the transfer set-up box ([APPS] choos 2 "i/o functions",and then select 5 "transfer". There you will find on the rightside of the screen "Chk:" . Here you can select the checksumtype. My calculator only disply's 3 dots next too the Chk fiels. Whene i put the cursor on the Chk field,and press F2 fore choos, a window appears, and i can select 3 checksumtype's. But i can choos what i like, but none of the choices will be put in the Chk field. The HP49g emulator, that also runs on ROM 1.17-B, state's in the checksumfield "3".
Erwin
