Re: HP25: Some Keys with bad contact Message #2 Posted by Frank Knight on 24 Mar 2000, 8:49 a.m., in response to message #1 by Jaime Tavares
I have had some success with stuffing a couple or few long strands of stainless steel soldering brush(avail Radio Shack in soldering tools) up into the contact area (plated through hole directly below key on keyboard and moving around circularly while pressing some on the keys,getting the strands between the contacts and over the edge of the PTH. This process done several times has gotten keys working that have formally not, as it does manage to scrub the contact area. Suggest you not overdo it, but it's worth a try before keyboard teardown, or keyboard replacement. Good luck, Frank
