Re: about Survey programs Message #2 Posted by db on 14 Mar 2000, 8:36 p.m., in response to message #1 by Naim
Naim - D'Zign has/had several versions of programs for the 48 series. Assuming the G has the same limitations as the S you can get what was called (i think) the student pac. it did most things yould want to do but had little or no point storage. They come on an ibm compatable flopy disk and you read them onto your 48 over the wire. If you are accostomed to D'Zign's 42 or 41 programs it will be familiar but will seem to run a bit slow; its a 48 after all. The address is:
Ted & Phylis Kerber D'Zign Software P. O. Box 430 Tollhouse Ca. 93667-0430
The phone # is (209) 297-8025
His stuf was the first, and for years only, camercially available program to have ofsets to spirals, three wire leveling,& EDM slope staking. If I worked for myself I'd still use Ted's stuff, it has limits but it dosnt have the built in bugs - and so errors - that TDS has. His tunnel tights program is probably the only one ever written. One thing: the 48 version is no better than the 42 version, and to me not as good because i cant change it to suit me, but its a LOT easier to put in the computer. And if your 42 does a memory lost; again, a lot easier to put..... - db
