HP48 turned on automatically after the OFF instruction? Message #1 Posted by Tal on 14 Mar 2000, 4:27 a.m.
Hello everybody, I wrote the following setup program to install the library ABC in HP48SX calculator:
%%HP: T(1)A(D)F(.); « CLLCD "INSTALLING ..." 1 DISP ABC 0 STO 'ABC' PURGE 'setup' PURGE OFF »
I wonder if there is a possibility that the calculator will be turned on automatically after the OFF instruction to complete the installation.
Thank you very much. Best regards, Tal td@chem.ch.huji.ac.il
