Re: Restoring Voyager Metal Bezel Message #1 Posted by db on 25 Feb 2000, 9:23 p.m.
just a thought: after removing any glue; using some small, hard, correctly shaped things for mini anvils and a bit of judicious tapping with a small rosin hammer, then passing it back and forth over a pad of green scotch-brite against a straight edge to keep the brushing parallel might help. unless its a 12 C. i did something like this on the damaged trim of my volvo 1800 and it did improve it. but so might seeing thoes dings as a badge of honor. by the time a casio gets scratched up, its dead. buen suerte
