HP49G problems Message #1 Posted by Mike on 24 Feb 2000, 2:28 p.m.
Would anyone out there be able to answer (or refer me to a location the can provide me an answer) to this problem? I have the HP49G calculator.
I'm unable to get it to do the following properly..
1) convert integer type values to real type values (i.e. convert 5 to say 5.00 (if FIX 2 set)). 2) Convert a real value of 5.00 to a string representation of "5.00". I can type in 5.00 (FIX 2), and convert using ->STR and what is displayed is not "5.00" which IS THE CORRECT STRING REPRESENTATION OF 5.00. Instead what is displayed is "5.". Hmmm??!?!?!! I've read the manuals from cover-to-cover and with no success. The 48 series does this properly (I know that HP has added a type for integers to the 49G).
Thanks anyone tons in advance! ! ! ! ! ! !
-Mike
