Simple wand instructions Message #2 Posted by Steve on 19 Feb 2000, 7:35 a.m., in response to message #1 by db
Plug want into any port
Hold want at about a 15 to 30 degree angle to the vertical (sort of like this \)
Press the bar on the wand that turns on the red light and sweep the wand across a barcode from the paper keyboard (smoothly) Then release the bar.
This should turn on the HP41, or if already on, cause the barcode to be interpreted and acted on.
You should cover the paper keyboard with a plastic sleeve, as the wand will eventually wear the paper.
You should move the wand at a rate of about 5 to 10 inches per second (from memory).
Move it this way <--\
I hope these quick instructions are of some help.
