Re: Why not switch to HP48 ? Message #9 Posted by Andrés C. Rodríguez on 14 Feb 2000, 7:52 a.m., in response to message #8 by Menno
How good are HP41 emulators for the HP48G series? (not SX).
If the emulators are complete and reliable enough, they are a very good alternative, for the Concorde and for some of us, -41 users/fans. Pray your application does not rely on barcodes, mag cards, etc.
Software compatibility via emulation is a minimum feature that newer models should always have, even without the hardware options. It should be part of the standard product. A program conversion utility (sort of a compiler), that could be run on a PC seems possible but rather complicated for these calculators.
The Concorde case may be a new opportunity to ask for an updated HP42S follow on, it will be more on the line of the -41.
