Re: HP-15c for celestial navigation?? Message #2 Posted by Ron Ross on 4 Feb 2000, 12:12 p.m., in response to message #1 by Brian Lynch
Yes. There is an older book (maybe out of print) on this also. He used an HP67 (the book is that old). The HP15c is more powerful though maybe only has about half the programming steps as a 67. That will be your obsticle, since the hp15c only has approx 1/3 K of ram. Check programs available for the HP32s (not the hp32sII). They may be similiar enough to use. I will check on the book title and let you know Monday if you are still interested.
