USRLIB Example Message #3 Posted by Joe Panico on 19 Jan 2000, 1:36 p.m., in response to message #1 by Tod Lewis
Todd, I looked-up the usage. If all is OK with your HP48 file, do the following: (I'll use your file names)
1) Copy the HP48 directory "Funts" to the PC in binary mode
2) c:\USERLIB Funts test
This takes the file "Funts" and creates a library named "test".
3) Copy the file "test" back to the HP48 in binary mode.
Try this and see if it works. If you want, send your example library source directory to me and I'll try it out.
Joe
