Re: Dead 11C Message #2 Posted by Reinhard Hawel on 9 Jan 2000, 7:42 p.m., in response to message #1 by Jan Stübbe
You might want to remove the batteries and shorten the battery contacts in the calculator to empty some internal capacities.
You could also remove betteries and push the ON - Button for a long time - that helps sometimes, because it's an interrupt to the CPU and the CPU needs more current from the internal capacitor. Note: this can take VERY long or may not work at all.
If you don't have success with this methods remove the batteries and let it lie in a drawer, let's say for two weeks or longer. That could help to discharge. CMOS has VERY low standby currents and this can take very long.
Personally I'd shorten the battery contacts. You can also clean the contacts - this wouldn't hurt anyway, even if you don't see some dirt.
