Bypass the 10 minutes auto shut-down? Message #1 Posted by Tal on 9 Jan 2000, 8:47 a.m.
Hello everybody,
I have a little problem with a program: The problem is that when the program is running and there is no key stroke for more then 10 minutes, there is an automatic shut-down. After that, when I press the [ON] key, the program doesn't reload again correctly. Is it possible to bypass the 10 minutes auto shut-down?
Best regards, Tal.
