Re: Hp41CX interfacing Message #2 Posted by Steve on 6 Jan 2000, 6:17 p.m., in response to message #1 by Gene P
If you have (or can get) an extended IO module, the commands OUTP and INP allow you to dump a program in the internal tokenised format to and from your PC via the RS232 interface.
There's no fancy protocol here, and you have to set up the PC (or whatever) to be ready to receive or to send at the right time.
Without the extended IO module, and with the printer switch on the bottom of the IL module set to enable, a PRP will allow you to dump a program in ascii through the RS232 interface.
There's no easy way of reading a program in ascii.
