Re: HP75D with wand Message #2 Posted by Jan H. Bos on 3 Jan 2000, 7:55 a.m., in response to message #1 by Henk Schellen
Henk, I can only tell you what I remember of the wand tool for the HP 41-series. It was an alternativ way of loading programs in the calc. HP published solution books, with software in the way of barcode strings. To load the program, you past the wand over the barcodes and the information was stored in memory. As the magnetic card reader was a (expensive) option for the HP 41, the wand was a cheaper alternativ. You should try to lay your hands on the appropriate software for the HP75D or find somebody that can make a copy of some software, you are interested in. Try the "clasified ads". Regards, Jan
