Re: HP11C display flashing- help! Message #2 Posted by Todd Garabedian on 18 Dec 1999, 1:44 p.m., in response to message #1 by Danny Kight
Dan,
I think you're using the wrong batteries. You should be using 357 batteries, not the the 303 type. The 303 probably has less juice because according to the 11C manual (p. 231), "an asterisk (*) flashing in the lower left corner of the display when the calculator is on signifies that the available battery power is nearly exhausted." Since those 303s are brand new, they're probably not providing the necessary power to the calculator.
I would go back to Walmart and exchange the #303 for #357, and that should solve your problem.
Good luck! Todd
